severe problems installing new turbo - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-12-2009, 06:07 PM Thread Starter
Exclamation severe problems installing new turbo
I am doing a turbo replacement on my truck. I got a schwitzer turbo made by borgwarner. The guy at a injection shop said that it was an identical match. Well Im trying to reconnect the exhaust side of the turbo, and the flange that connects the pipes from exhaust manifolds to the turbo will not line up. I cant figure out why its not mating to the turbo. there is a gap in the bottom of flange and the pipes from the exhaust manifolds are hitting the block. is there some way around this or what do i need to do?
mthayer is offline
post #2 of 4 Old 05-12-2009, 06:07 PM
wriott
Guest
Posts: n/a
Quoted: Post(s)
what motor?
post #3 of 4 Old 05-12-2009, 06:26 PM Thread Starter
97 7.3 powerstroke
mthayer is offline
post #4 of 4 Old 05-13-2009, 04:34 AM
wriott
Guest
Posts: n/a
Quoted: Post(s)
you up pipes may have getten bumped. they can move around. if they did then check to see if the doughnuts got damaged
