Turbo Replacement - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-11-2009, 03:20 PM Thread Starter
Turbo Replacement
Unfortinately, the turbo on my truck decided to come apart on my. I got a replacement, but im having trouble getting the old one off. The problem is getting the bolts out of the exhast side going to the exhast manifold y pipe going to the turbo. any suggestion on getting them out?
mthayer is offline
post #2 of 12 Old 05-11-2009, 03:31 PM
duct tape & zip ties
bigcountrysg's Avatar
Lots and Lots and Lots of pb blaster. Did I meantion you need lots of pb blaster.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 12 Old 05-11-2009, 04:00 PM Thread Starter
I got the top 2 bolts out no problem. The problem is with the 2 nuts on the underside. i just can figure out a way to get them off. once Those two are off, then its almost done. any help?
mthayer is offline
post #4 of 12 Old 05-11-2009, 04:08 PM
Remove the clamp that holds the Y pipe to the turbo. Then you can remove the turbo out of the way. Really no need to remove the Y pipe from the Up pipes.
2002 7.3L burnt
post #5 of 12 Old 05-11-2009, 04:10 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
subscribed
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #6 of 12 Old 05-11-2009, 04:14 PM Thread Starter
It is on the exhaust side of the turbo. I just cant get the nuts off the bottom two bolts. I really need to have this running tonight, cause I need to haul a backhoe tomorrow. everything else is disconnected except the pedistal.
mthayer is offline
post #7 of 12 Old 05-11-2009, 04:17 PM
Remove the down pipe, remove the clamp for the exhaust Y pipe, remove the clamp for the intake Y pipe, Remove the ebpv acctuator arm, remove the waste gate, and then reomve the two bolts that hold the turbo to the pedistal.
The only thing I forgot to mention is to remove the intake off the turbo. What two nuts are you talking about.
2002 7.3L burnt
post #8 of 12 Old 05-11-2009, 04:27 PM Thread Starter
Got the down pip, air intake, the y pipe for the intake, The waste gate, The actuator, all that. The problem is where the exhast manifolds connect together on the back of the block. There is a Y pipe back there, and that bolts onto the exhaust side of the turbo. its the 2 9/16 nuts thats that im having the problem getting to. Its a 97 with a garret turbo.
mthayer is offline
post #9 of 12 Old 05-11-2009, 04:30 PM
Hmmm on the 99-2003 the exhaust Y pipe is held on by just a band clamp. Sorry man really don't know being never took a turbo off an obs truck.
2002 7.3L burnt
post #10 of 12 Old 05-11-2009, 06:05 PM
gmsmith36's Avatar
Extension with a wobble end. Perhaps a 1/2 indrive reduced to 3/8 drive. I am assuming you are having trouble breaking them lose or are you having trouble getting a wrench on them.
gmsmith36 is offline
