After sitting over night????????
I just picked it up from ford & they replaced 3 injectors & the fuel pump to try to correct this problem! As you can see it didn't work!!!!!
![]() http://www.youtube.com/watch?v=CbQCoEoPjfg |
What year is it? 7.3 or 6.0
Its a 6.0 Is that all it is doing is smoking? and does it only doing after sitting over night? Also, that thing took forever to start up. How are your batteries?
Goose I don't no squat on a 6.0 but look at the tac when its being cranked
Brand new batteries & that's all it doe's after sitting for a while other than that it runs fine! They changed 3 injectors & I was told it was still a injector issue.
try getting a reflash and see if that helps. Smoke is normal at start up(maybe not as much as you have) but it should not take that long to crank with good batteries. I would also test your batteries. I have bought new batteries that wound up being bad.
Maybe a Tech will chime in and help you out more than I can. |
for a tech, looks like bad injector,or seals to me.
