Changed primary filter ran for 1 miute died wont refire - Ford Powerstroke Diesel Forum
Old 04-24-2009, 03:19 PM
I am having problems with my 03 6.0 liter dually. I changed the secondary filter 3 days ago. The truck ran fine. Then today I was changing the oil, and I thought I would do the main one while it was on the ramps. I did not know about releasing the fuel pressure soi I got a bath. I installed the main filter put trhe cap back on. Finished my oil change. I fired the truck up and it fired up fine. I was backing off the ramps and it started to chug. I was backing down my driveway thinking it was just purging the air. When I got to the end it died. I pulled the secondary cap and it was dry. Left the cap off and kept turning the key repedidly and the secondary began to fill up, so I know the fuel pump is working. It got completly full put filter and cap back on, and it will not fire.It tries it just wont fire. Am I missing something. I really hate to get it towed. It stuck on the street Help!!!!!!
Old 05-04-2009, 04:33 AM
Did anyone reply to you on this? I have a 7.3 and I am having the same issue. I changed the fuel lines, it started, ran for a short period, started chugging(very loud) then died and won't start. I checked fuel bowl and it was down so I filled and kept cycling the key to prime, but it still won't start.
Old 05-06-2009, 08:07 PM
What brand of filters did you use
Old 05-08-2009, 10:46 AM
Primary filter is on the suction side. Did you fill the filter full of diesel? Fill both filters full and then try to start it.
Also is there any o-rings on that primary filter? Did you drop one or not replace one? Or you did not get it on correctly.
