my truck wont start it will crank over for a long time but just will not catch fire idk what to do or where to start! truck is a 96 350 with the 10K mod, k&n intake and a 3in dp.
first thing to check is check to see if its getting fuel.
i can smell the fuel coming out of the tail pipe and it blows white/gray smoke while cranking over
need to get a scanner on it and look for codes , also need to read data with a scanner and see what it doesnt have , rpm signal, oil pressure , things like that , just because you see some smoke and smell fuel doesnt mean it has fuel pressure either
^^^^^ what he said ^^^^^
plug it in and see what it does brother
quick update i tested both batteries and one failed so i went and got 2 new ones from advance auto put em in truck cranks over much better but still wont start i also pulled the fuel filter and it is full of fuel looks clean and filter does not appear to be clogged. i would put it on a scanner but i dont have one
![]() i think it might be the glow plug relay it was really hot the other day when i had the same problem the night before and now it is cold to the touch does not warm up at all
if the glow plug relay went bad could it take out the glow plugs with it? i am still fairly new to this
You don't need glowplugs to start it. I think.
really??? it is still about 45 here i thought that i needed them to start the truck if not then y are they there lol?
