LIFT PUMPING LEAKING! Will it cause this? - Ford Powerstroke Diesel Forum
Old 04-18-2009, 06:37 PM
Today I noticed my lift pump started leaking, would this be the cause of some of my problems listed below?
Still have my low mileage (51-K miles) 1997 Powerstroke with miss at idle and hard shifting at times.
First found it had bad fuel, have run it 3-k miles with different treatments and 5 new filters.
Have run the buzz/con test 3 or 4 times total now and everything show to be working fine with a code of P1111.
Run test on transmission found NO CODES and everything is fine on the inside.
When driving the truck a little hard it act as if the air filter is stopped up or like the exhaust is plugged up. Removed cat and muffler (no help there) Opened top of air cleaner and does not seem to suck air like my other trucks do! It is pulling some air in, but when I removed the top of air cleaner of my 277-k mile 1997 Stroker it will suck you hand into it.
I can idle the truck up just a little and seems to run better.
Forgot to add, truck has NO SMOKE!
Old 04-19-2009, 06:49 PM
Well, since no one has replied I guess the lift pump is not the problem.
Old 04-30-2009, 01:17 PM
I FIXED THE PROBLEM
After 3 months and not being able to solve the problem on my low mileage truck with a miss and hard shifting. I finally FIXED IT today for $4500.00!
I SOLD IT!
Now somebody else can spend money on it!
Old 05-01-2009, 06:09 AM
Glad ya got rid of your headache, I'm just disappointed nobody replied to your thread to help ya out. Sorry ya fell between the cracks.
