6.0 F-350 PSD no throttle control
I've searched for four days on this and can't get anything. Please help!
RIG- 2006 F-350 PSD, 60k MODS(problem related)- EDGE Juice Platinum, Intake, Exhaust DTC CODES- P0198 (EOT Temp Input High) SITUATION: Took the truck to the dealer(minus programmer/any trace of it) to have the EGR Cooler checked out. Turned out to be the radiator cap. Picked truck up and noticed the clutch fan was louder than normal. Then pulled two DTC codes(P0198 and P1000[not worried about this one]) as I was driving home I stopped at a light and the truck applied throttle by itself, no joke. I shifted into nuetral and the engine revved from idle up to about 2500-3000 RPM's by itself for a few seconds, then idled fine. This is still happening, and I went over a speed bump and the whole truck shut off. Not due for an oil change and haven't seen any other answers. |
Nobody has any ideas?
I would start checking your wiring harness connections, sounds like the electronic throttle control wires may have a bad connection? If you unplugged any harnesses to install the edge unplug them and closely inspect for bent/corroded pins.
Found it! EDGE Unit itself is bad, sending it back this week to get it sorted out. Thx guys
Ohh, I thought you had the edge out when this happened.
Nope, I still have to send it in to get a new one from them, sucks that it happened but I uninstalled it and the truck works great again...
