truck put out white smoke wont accelerate
i have a 2004 f250 4x4 6.0 diesel it quit on us yesterday was able to limp it to a buddies house it would not accelerate and when i pushes the gas it put out big puffs of white smoke but didnt smell like coolant then when i came back to load it on the trailer i went to move it and it did the same thing then all the sudden it just stopped doing it and i was able to drive it home with no problems i was told by a freind that it was unburned deisel and that the veins were sticking in the turbo any ideas would be a big help
i have since drove it today it didnt do that but if u let off the gas then pushed it again it would hesitate and puff out black smoke till u let off then if u pushed the gas again it would be fine till u let off and tried to accelerate again |
Is it blowing out coolant thru the overflow tube?
Sounds like your EGR valve is hanging open. If this happens you'll get a no boost situation and your truck wont be able to get out of its own way. If you have a boost gauge look and see if it reads anything when it happens. Not sure about the white smoke...you will usually see a good bit of black smoke because you are pumping more fuel to accomadte for the boost that just isnt there. Go and get checked for codes and if one happens to be P0401, P0402, or P0404 then that is most likely your problem.
thanks for all your help i deceided to take it in to the dealership yesterday afternoon so we will see what they say and ill post what the problem was so that others with the same problem might see it thanks for the help james
same thing happened to me it was a injector
finally got the truck back thursday it need a fuel control valve an egr valve and the intake was full of carbon so it had to be cleaned out dealership was really nice gave me a break on the price even
