truck died....no start....
like it says this morining i was on my way to school and i was bout ready to shift between 4th and 5th and all of a sudden my truck died.....now it wont start....i even tried to lit it with either and nothin...it just rolled over quick with the either shots then stopped.....so i think its my fuel filters again....i fukin hate the beans system...the filters are odd ball as hell and no one has them.....or its somethin else....i took the top off my 5micron filter and barely any fuel came out whereas on my 30micron it dumped out so im guessing that the filter is clogged again....it seems like so far out of the 5months ive had this truck i think i put new filters on 3times this will be #4....so any ideas are welcom.....
You have a gauge on the system? What kind of fuel pressure are you seeing? If poor I would try to find where your fuel contamination is coming from.If OK maybe a CPS. JJ
idk what my pressure is the truck isnt running......and im the only 1 here so i cant roll it over nad watch
i know its not getting fuel....there is absolutly no smoke from my stack......
nobody has anything???? i watched my fuel pressure and it was at 50 where it would normally be at 65.....i cant figure it out....why wont it start.....could it be my hpop took a sh!t??????
50 psi is plenty to get it to start. Yes your HPOP could have taken a poo but I do not think that is the issue. Have you checked your fuses? Maybe the fuel bowl heater shorted and took out the fuse? Do you have a spare CPS you could try?
my dad talked to the ford dealer and he said pri not my hpop....could be but pri not.....i have lots of fuel..i took the line off and rolled it over and covered my engine with fuel.....i dont have the fuel bowl thing any more with my beans system...atleast i dont think i do...my filters are on my frame....by the tanks.....then a line goes up to a 3 way thing....1 goes to the back of my driver side head...1 to the pass side head and 1 to my fuel line....thats where i took the line off.....
yeah i read it...i dont have a fuel bowl heater....its gone along with my pump....and canister....all i have is my hpop up in my vally....the only thing we came up with is that the fuel regulator(on the side of the hpop) is sticking or somethin...possibly closed....its the only thing we can think of....one of my dads buddies that does diesels said the same thing...so idk im gonna change that and if it dont work idk what im gonna do....also its kicking no codes....which sucks.....
