help! no start after high ps oil pump install - Ford Powerstroke Diesel Forum
Old 03-26-2009, 10:51 AM
replaced the high pressure oil pump because it was leaking, and replaced two fuel lines that are on the same bracket that come up from the frame rail behind the alternator and into the driver side of the fuel filter housing, replaced the fuel filter and filled the bowl as well. Now when i go to start it, it only starts when i have a gas soaked rag to the intake, and it doesnt run well or for very long. Any suggestions????!!! Pretty sure it hasnt had the CPS recall done, but it was running fine except for the oil leak before i did the work
-Jordan-
Old 03-26-2009, 11:35 AM
Year/Engine?
Old 03-26-2009, 11:36 AM
Originally Posted by BadInfluences View Post
Year/Engine?
2001 7.3 powerstroke
Old 03-26-2009, 11:37 AM
is there oil in your HPOP reservoir? not a tech just throwin some ideas out
Old 03-26-2009, 11:38 AM
yep checked that theres oil in there.
but keep the suggestions coming my luck its just something simple that i overlooked
Old 03-26-2009, 11:40 AM
describe doesnt run well? and are the fuel lines leaking?
Old 03-26-2009, 12:45 PM
Illiana Chapter Director
Probably has air in the HPOP lines.
Old 03-26-2009, 12:56 PM
a truck
Try this for air in the HPOP lines, I had the same problem you did and it was just air in the lines that just needs to be worked out
This is what Dhanna6powerstroke posted up for me on my help thread before
You need to crank the truck at 10-12 second intervals, (wait 20-30 seconds between cranking intervals). After trying 3-4 times, let sit without cranking for 4-5 minutes and let the starter cool off. Repeat as necessary. He said that it should fire up. Once you get it started, raise the RPM's slightly and hold it steady. Keep uss posted on progress. Hope this helps some.
Old 03-27-2009, 04:08 AM
thanks but i mean it starts up like its going to run fine but, the rpms drop and drop until it dies, but as soon as i pull the gas rag out of the intake it almost immediately dies.
I've tried to start it plenty of times in intervalls as well, but i'll try it a few more times i guess.
also no leaking fuel lines i've check any fuel line that was taken off multiple times.
Old 03-27-2009, 05:16 AM
It is running on the gas fumes. Open the drain on the fuel bowl and turn key to on and make sure you are getting fuel to the bowl. once you are sure you are getting fuel close the valve and cycle key and listen for the fuel pump to turn off do this a few times. Than do as matt said.
