oil pan removal - Ford Powerstroke Diesel Forum
Old 03-24-2009, 08:44 AM
oil pan removal
Hi, Has anyone been able to remove oil pan on 2000 7.3 without removing engine? Suspect cracked or plugged suction tube, debating to pull eng or try to remove pan.
Thanks
Old 03-24-2009, 08:51 AM
The problem is getting it back on. and that can not be down with the engine still in.
Old 03-24-2009, 09:04 AM
International Threat
Pull the engine, it's far to easy then jerry rigging it under the truck and then having to do it again because you didn't get the pan to seal properly.
Old 03-24-2009, 09:24 AM
Powered by Deez Nuts
pull the engine. thats the only option you have if you want it done well.
