1999 7.3 Powerstroke surging - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-11-2007, 03:24 PM Thread Starter
I 've got a 99 7.3 that has started to surge just under normal pedal pressures, not under acceleration or load, because then it spools nicely and accelerates with no problems. Whats up with this motor, its almost new (125,000 miles) I have read some others listings, but don't see anything quite the same as my problem. It just surges, pretty bad under normal driving. Thanks for any help, this is driving me nuts. Mark
maxdogk911 is offline
post #2 of 3 Old 01-21-2007, 08:42 AM
Mine does the same thing? Just recently noticed it but it seems to be there at very light throttle all the time now.
Lextek is offline
post #3 of 3 Old 01-27-2007, 02:13 AM
straycat's Avatar
Mine did the same thing, but it was up around 40-50mph, turned out to be a bad injector, replaced it and it was back to normal. I don't know if that is the same thing your talking about, but I thought I'd let you know so you can check.
Gord.
SKILLFULLY DISGISED AS A RESPONSABLE ADULT.
99.5 F350, CC, LB, DRW.
7.3 AUTO 4.10s
AUTOMETER C2s EGT, TRANS, BOOST, OIL, FUEL PRES
ATS, WW, SSHPX, B ANNIH.
DP 6P 140EX.
AFE MAG F STG 2.
MAGNAFLOW 4'' TURBO BACK DUALS.
US GEAR SUPER D-CELERATOR
500LTR FUEL TANK
BILLET GRILL
ALARM & REM START/ ELC BAT DISC.
CB, SAT, GPS, PANASONIC CD, 5th WHL
35' GOLDEN FALCON
Been a mod longer than TJ hahaha
straycat is offline
