will a faulty pcm cause injectors to fail? - Ford Powerstroke Diesel Forum
Old 03-12-2009, 05:10 PM
the dealer first said 6 injectors were bad, then it was all 8. they wouldn't warranty it due to a code P1000 which they said is caused by a programmer. they replaced all 8 and it still isn't fixed so now they say the pcm may be faulty. could a faulty pcm cause the injectors to fail?
Old 03-12-2009, 05:14 PM
Send a message via AIM to troid123
They have to be able to prove that a tuner caused the problem. As for the code, I dont think that has ANYTHING to do with having a programmer. You need to start fighting that is complete BS!!!
