IPR, injection pressure regulator, please help - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-10-2009, 08:52 PM Thread Starter
dsl_pwrd_ford's Avatar
what are the symptoms of this failing?
my trucks idle is fluctuating, and it's starting to buck a little under acceleration.
Pat
2000 Ford F-250 XLT Power Stroke 7.3, 4x4 EC LB SRW
TS Performance 140hp Chip, AFE Stage 2 Intake,
dual 6" mitre stacks, 4" suspension lift, 35" Pro Comp Muds,
SB Clutch Con-O, Gauges, HP Oil Crossover, Zoodad, AIH Delete, Marinco, Foil Delete
MAP Maximizer & Boost Tube, Snow's Boost Cooler Stage 1.
Nebraska Power Strokes
dsl_pwrd_ford is offline
post #2 of 9 Old 03-10-2009, 08:55 PM
SMKSTAX's Avatar
Straight from dieselmann's site:
No/hard start hot or after stalling, usually re-starts after cool-down; Jerky, irratic idle; Possible DTC#'s P1211, P1212, P1283:
Usually caused by low injection oil pressure or regulator (IPR) valve. High pressure oil is used to pressurize and inject the fuel into the cylinders--each injector is essentially its own injection pump. The IPR is a by-pass valve that controls the high oil pressure depending on demand.
RICK
97 F350 CREW CAB 4x4, 7.3 TURBO DIESEL, DIY INTAKE , TW TUNES
GRAND ROCK POWERFLOW STACK KIT W/5" MITRES
3.55 REARS, 3" DOWNPIPE, FPR SHIMMED WITH GAUGE
SMKSTAX is offline
post #3 of 9 Old 03-10-2009, 08:57 PM Thread Starter
ok, would those symptoms point to ICP, IPR, or IDM?
Pat
post #4 of 9 Old 03-10-2009, 08:59 PM
SMKSTAX's Avatar
IPR.........dang 10 letter limit.
RICK
SMKSTAX is offline
post #5 of 9 Old 03-10-2009, 09:04 PM Thread Starter
good, i got a spare coming tomorrow. we'll see what it does
Pat
post #6 of 9 Old 03-10-2009, 09:05 PM
SMKSTAX's Avatar
Don't count out that it could be the CPS. Unless you changed it recently.
RICK
SMKSTAX is offline
post #7 of 9 Old 03-10-2009, 09:07 PM Thread Starter
i had it changed under the recall last summer
Pat
post #8 of 9 Old 04-29-2009, 05:45 PM
Motown Fire's Avatar
Any updates to this ???
Delmar Expedited Transport
Oil Field Freight & Hot Shot Services
Motown Fire is offline
post #9 of 9 Old 05-01-2009, 07:53 PM Thread Starter
i swapped in a salvaged pressure sensor and it fixed it
Pat
