CMP ICP MAP codes with rough running 7.3L - Ford Powerstroke Diesel Forum
Old 03-09-2009, 08:49 AM
Question CMP ICP MAP codes with rough running 7.3L
Hope it's OK to post IH DT444E problem here?
'99 IH DT444E Flatbed Tow Truck
3 months ago - rough running then no start - Changed CMP sensor per codes
1 month ago - rough running no start - Changed CMP sensor Again per codes plus mechanic advised CMP sensors are unreliable
Just to Muddy the troubleshooting waters - pumped fuel from another truck into this truck so we could change a fuel tank on other truck.
About 1 week after fuel transfer - on and off rough running started but evens out suddenly and goes for day or so no trouble - happened 3-4 times in last week - assumed we transferred dirty fuel.
Changed fuel filter which did not look too bad.
Cleaned fuel strainer which was pretty full of rusty looking grit.
Now - rough running non stop - cleared codes - set 3 new codes immediately on test drive:
143 - Wrong number of CMP signal transmissions per cam revolution
124 - Injection control pressure signal out of range LOW
122 - Manifold absolute pressure signal is inactive
Any thoughts? Reading through threads, I am suspecting Valve Cover Harness. Any further testing I can run to narrow down the problem?
Thoughts on what else might be gunked up by gritty fuel?
Need to get this truck up ASAP - I'm a 3 truck operation so 1/3rd of my
"fleet" is down!
Thanks,
Teresa
