Help please! Did I Blow it up ??? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-07-2009, 05:11 PM Thread Starter
Angry Help please! Did I Blow it up ???
I'm new here (just read a LOT) - I bought a 1999 E-350 with a 7.3 recently from a friend, and JUST put a new Muffler (Aero) and trailer hitch on..... (it also has a Striker Power Module on it that was at the time, set all the way up to 5 - ?)
While I was out playing with the cool new muffler to see how much better it ran, under heavy acceleration, it made soft popping sound (from the engine compartment), "Service Engine soon" idiot light came on & it lost power but continued to run - as I was less than a quarter mile from my house, I continued gently down the road, it still responded to throttle, and I even heard a sucking sound when I let off the gas.... (I thought maybe it got carried away on Boost & maybe blew something loose on the intake side)
As i pulled off the highway, it died & would not start, THEN as a couple people helped me push it to the side of the road, I saw a BUNCH of engine oil where it had sit for a few minutes.....
No Rod hanging out or anything, and it seems like the oil came out on the topside of the motor, as the passenger side underhood area is DRENCHED with motor oil and even had oil running down the Grill.
I don't hear any bad noises when it cranks, and it still cranks over fast (maybe TOO Fast?) - but thats about all I have for info now, as it is dark out & I have to work all night.
If anyone has any helpful ideas, or obvious questions for me, I will check back as much as i can till I go to work.
I'm an OK shadetree mechanic, but my diesel experience is very limited and I would appreciate ANY INPUT! - THANKS!!!!!!
FLFXR is offline
post #2 of 8 Old 03-07-2009, 05:38 PM
PSDfan99's Avatar
Blown high pressure oil line maybe? Those lines make a huge mess when they go. Take a look in the engine valley and look for 2 steel braided lines (one to each head) and see if one is leaking or blown apart. If it is blown, it will not allow the truck to start and it'll make a mess like you described.
Early 99 F-350
4" lift on 33's
Tymar Intake, Isspro Gauges, Modded IDM, HPX, Boost Fooler, 4" Exhaust
-BTS Tranny
-76mm Sledgehammer
-Swamps Tuning
-230cc Casserly Hybrids
-T.E. Modded 17* HPOP
-ARP's, Chromoly's, 910's
-ITP RR
-Jake
PSDfan99 is offline
post #3 of 8 Old 03-07-2009, 06:26 PM
and find out what code it threw. i'd start there.
2000 F350 SRW EC LB 4X4 OFFROAD
WASTEGATE DISCONNECTED
EBPV EXHAUST BRAKE MOD
MANUAL TC LOCKUP SWITCH MOD
MAX COOL 40K TRANS COOLER IN SERIES W/ V10 COOLER
TRIPLE PILLAR GUAGES(EGT,TRANS,BOOST)
WICKED WHEEL
PHP 6 POS CHIP (1:STOCK, 2:45 TOW, 3:60 TOW, 4:80 PERF, 5:HIGH IDLE, 6:NO START)
DIY TYMAR INTAKE
MUFFLER DELETE
thomasinnv is offline
post #4 of 8 Old 03-07-2009, 06:31 PM
stillstrokinit's Avatar
check your hpop lines like psdfan99 said same thing happened to me. good luck let us know the outcome
1996 F350 4x4 Crew Cab long box. powerstroke e4od
168000 miles
33x12.5x16.5 BFG MT
K&N intake
Edge evolution
Home made exhaust
add a leaf up front
First hook ever. 275.3 feet. 4th place
out of 4
stillstrokinit is offline
post #5 of 8 Old 03-07-2009, 08:08 PM Thread Starter
I feel a littel better - THANKS!!
I got the same "guesstimate" from the former owner - (High Pressure line)
But I do appreciate your responses, and am not as worried as I was earlier.
Thanks to all & I will let you know when I confirm what happened.
FLFXR is offline
post #6 of 8 Old 03-16-2009, 11:52 AM Thread Starter
OK, Found the problem.... Now.... ???
it's one of the High Pressure oil pump lines - now can anyone guide me to a source for replacement lines other than ? I figure I better replace them both, since one sprung a leak right in the middle of the line.
FLFXR is offline
post #7 of 8 Old 03-16-2009, 03:32 PM
PSDfan99's Avatar
Ford or International is probably the best (and maybe the only) place to get those lines. If you buy the lines from Ford or IH, they will last a long time ans will be a direct replacement. I wouldn't buy from any other source.
Early 99 F-350
4" lift on 33's
-BTS Tranny
-76mm Sledgehammer
-Swamps Tuning
-ITP RR
-Jake
PSDfan99 is offline
post #8 of 8 Old 03-17-2009, 07:55 AM Thread Starter
IH Part #'s ?
I figured the dealer would be the best & Probably only option.... if anyone knows part #'s for IH, I would like to check with my loacl tractor dealership (they don't have the books for the 7.3, but can order with a part #)
Thanks!!!
FLFXR is offline
