Attention diesel techs! - Ford Powerstroke Diesel Forum
Old 03-05-2009, 04:01 PM
Hello, my friend has a 96 f-250 with a 7.3 stroke. He went to change his glow plugs and to his surprise the dang things were stuck in the head as in they uncrew but are still stuck like the ignitor part is in the combustion chamber. Well, he got one out and on the next one the glow plug came out all but the tip it is stuck in the chamber still. He was advised to crank it like taking a compression test and see if it would blow out. It didn't and now only thing we know to do is pull head Is there anything anyone has done to keep from pulling the head I mean like some type of trick or something. I know of some old diesel techs that said this isn't a real uncommon thing to happen on trucks with higher mileage but they said pull heads. I know if there is a will there's away that someone has figured some kind of way out maybe
Old 03-05-2009, 04:33 PM
Don't think anyone that I know of has had enough will to figure out a way. Pull the heads. JJ
Old 03-05-2009, 04:51 PM
Cynic
Advised to crank it??
Old 03-05-2009, 04:56 PM
yea because the compression of the engine could possibly force it out the hole backwards I know kinda sounded scarry to me as well but came from ford diesel tech 30 years experience
Old 03-05-2009, 05:01 PM
I could understand this theory if the tip was still stuck in the hole and it was lined up just needed a little push of compression from the back side but if the tip is just floating around in the chamber then NO DICE!
Old 03-05-2009, 05:03 PM
Cynic
And what happens if it gets sucked in??
I know it sucks, but pull the head. I know of a few people that used a thin punch and knocked it into the cylinder. Replaced the glow plug.. and fired it up.
Didn't work out so well.
Pull the head.
Old 03-05-2009, 05:12 PM
do like everyone says pull the head its not to big of a job (if you have the tools) just bite the bullet and do it theres no other way trust me ive been there at my shop
Old 03-05-2009, 05:18 PM
I agree pull it.. and if i had my head off i would probably go ahead and replace the head bolts..
Old 03-05-2009, 05:19 PM
Studs* sorry.. not bolts..
Old 03-05-2009, 05:21 PM
yea thats a great idea hell while your at it might as well huh
