Truck idles won't move - Ford Powerstroke Diesel Forum
Old 03-04-2009, 02:07 AM
I was out plowing Monday truck sputtered CEL came on and went to idle only mode.No trouble codes from scanner.Still has open recall for CPS
When it's idleing it runs fine,no smoke,wouldn't it rough idle if it was the CPS?
Checked fuses and wiggled wires to VC harness, CPS
A buddy told me to replace the accelerator pedal,but wouldn't that throw a trouble code?
Old 03-04-2009, 03:15 AM
Send a message via AIM to ABoyAndHisToys
Mine idled perfect when my CPS went out with no codes. As soon as I stepped on it alittle it would die. Whats you RPM'S doing when cranking?
Old 03-04-2009, 03:51 AM
It starts right up and idles fine,just no go pedal
I just called the tow truck to bring it to the dealer for the recall and probably the 85 diagnosis
Old 03-04-2009, 03:54 AM
I'll bet it's the CPS......Good Luck!!!
Old 03-04-2009, 10:51 AM
They just called getting no power to the pedal said they need a couple hours to find the short
Old 03-05-2009, 01:45 AM
She's all better now,wire chaffed from PCM to accelerater pedal I guess I should look at the rest of the wiring since I live on a bumpy dirt road!
