help!!!!!!!!!
Ok to start out my truck was running like crap and would die every ones in a blue moon so i got new injet beans stag 2 and a Regulated Return Fuel System. so i got new glow plugs and new valve cover gaskets and i installed them yesterday. got it all on and the truck started up just fine (was running bad bc of the oil and fuel) and i let it run for a min or two and shut it down and pushed it out of the shop then started it up again but it never really got running good and the ses light was on. today i started it up and found that icp was not hooked up up so i plugged it in and revs up just fine but when it ideals down it feels like there is a mis fire and at ideal. so i did a buzz test and was good and cly 8 came up when we looked at the injets, check the oil and changed the fuel filter. every thing is the same please help
The regulated return is at 68 psi
