No power - Ford Powerstroke Diesel Forum
Old 02-28-2009, 07:40 AM
No power
I have a 1997 that idles fine but when you step on the accelerator it hesitates real bad. It has the check engine light on also. The problem seems to be more when the engine gets up to temp. Thanks Jim
Old 02-28-2009, 07:53 AM
Shaking the Bush Boss
sounds like a fuel issue.... have you had the codes pulled?
