Weird whirring and lots more smoke - Ford Powerstroke Diesel Forum
Old 02-26-2009, 11:18 PM
Send a message via AIM to Shaolin Crane
well over the last couple months my truck has started to smoke less and less, thats with my extreme race tune from IDP, today i was cruising on the freeway in traffic and i stepped on the throttle a bit and when it shifted a HUGE clous came out of the exhaust, covered the entire freeway, first time i didnt think anything of it, then it did it 2 more times, then i got to work truck sat for about 3 hours then when i left there was a LOUD whirring noise coming from the turbo, not a whistle but like it may be leaking or rubbing or something, any help is appreciated i can't have the truck down.
Old 02-27-2009, 05:30 AM
You said it sounds like it is rubbing? What is your boost levels? Pull the intake tube off of the turbo inlet and see what kinda play you have on the wheel. Sounds like you may have popped a turbo which would explain the big cloud because you were fueling it but had low boost. JJ
Old 02-27-2009, 05:39 AM
Check all your IC boots also!
Old 02-27-2009, 07:47 AM
my boost levels were still around 25-32
the only basis i have for it sounds like its rubbing, is my dad turbo starting making a similar noise and sure enough like 3 weeks later his turbo took a ****
Old 02-27-2009, 10:54 AM
ok IC boots are fine
Old 02-27-2009, 10:58 AM
What about the spider boots!
Old 02-27-2009, 11:23 AM
those have a bit more gunk than usual bit them seem tight
Old 02-27-2009, 03:08 PM
Did you check turbo shaft play? How much did you see up/down/in/out
Old 02-27-2009, 10:34 PM
i havnt had a chance yet. i need to get the mustang off the jacks before i can look at the truck
