Oil Leak - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-04-2007, 02:54 PM Thread Starter
Unhappy Oil Leak
Just came back from the store and oil is pouring from underneath truck.Drain plug and filter are tight.Oil all over engine compartment. Only seems to leak when running. Appears to be coming from top of motor.Are there any oil lines that could have broke that i can't see. Any help would be apprec. 2000 f250 7.3 6speed 175.000miles
HEVY HITTERZ is offline
post #2 of 4 Old 01-05-2007, 01:51 PM Thread Starter
oil leak found
Found the oil leak today. It was a broken o-ring on high pressure oil pump end fitting.Bought o-ring kit from ford and oil leak is gone.
post #3 of 4 Old 01-10-2007, 02:21 PM
check behind the fuel filter on top of motor, see if any oil, mine was coming out of the (high pressure oil pump) below the filter
harley1974 is offline
post #4 of 4 Old 01-10-2007, 02:38 PM
International Threat
Marty's Avatar
Glad you got it fixed!
Now that you know how much they charge and how to fix it... next time just buy the ORings from a hydraulic shop... at $0.25 per Oring.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
