Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 01-27-2006, 01:53 PM
250stroker 250stroker is offline
Pcm
my evolution is reading a pcm keep alive memory code does anybody have acess to the wiring diagram to the pcm
Old 01-27-2006, 05:21 PM
lancer lancer is offline
There is a memory code stored in your pcm. You may need a scanner to retriev it. You will also need the scanner to erase it. I don't think you have a wiring problem.
Old 01-27-2006, 05:41 PM
mschn99 mschn99 is offline
either my post did not take, or this guy made two threads on this, but you are right, a KAM code means a hard fault and it must be fixed to clear the code and keep it away.
