Stumped - Ford Powerstroke Diesel Forum
Old 01-03-2007, 08:14 PM
Stumped
No Start Issue
I Have A 1996 250 2wd I Had To Replace The Cps And Glow Plug Selnoid. 10 Days Later No Start Lots Of White Smoke. I Had To Start It With Either, Not Good I Know. Now If I Don't Plug It In At Night It Won't Start Even When It Was 72 Degrees Out. Once It's Started No Problems. The Voltmeter Stays Low For A Few Minutes After It Is Started. So If I Can't Plug It In I Am Stuck. The Truck Is Bone Stock Running On B20 Biodiesel. Any Help Would Be Great.
Old 01-03-2007, 08:34 PM
The Fat Mod
Maybe Marc or one of the techs will see this in a few. Hope you get it figured out.
Cheap plug, check out the NC section if you have not already
Old 01-04-2007, 01:47 PM
International Threat
Wish I was at home, I have a thread I saved that was this very topic!
Marc, stroketechintraining, or DJ's diesel will be able to assist. I have an idea but can't tell you from expierience so I'll leave this one be!
Old 01-04-2007, 09:41 PM
Send a message via AIM to ~CrazyDiesel~ Send a message via MSN to ~CrazyDiesel~ Send a message via Yahoo to ~CrazyDiesel~
Where abouts in North Carolina are you located??
Old 01-06-2007, 01:55 AM
Stumped
I am located in Hickory NC. And again it was 48 degrees last night and no start without the spray. So I have got to find the problem out soon.
Any help would be great.
Thanks in advance
Old 01-06-2007, 08:33 AM
Sorry, can't help you in person, I am about 5 hours east of you.
comon, stroketechintraining where are you??
Old 01-06-2007, 08:42 AM
BIG TRUCK, SMALL DRIVER
It is normal for the volt meter to read low after starting, while the glow-plugs run their 90 second cycle. Have you replaced the plugs?
Old 01-06-2007, 08:43 AM
ADMIN AND TECH
start with the basics ,oil level and quality , if have access to scanner ,may even pull codes, fuel pressure ,i would start there
