2000 7.3 ran out of fuel, now refuses to run
Has 1/4+ tank of fresh fuel, new filter, fuel filter bowl is full. Won't even fart.
Cycled the key 20 times, no change. Can running it out damage the pump? I need answers, the truck sits on the side of a narrow road as I type. |
probably got alot of air in system, does take tim to get air out
ON THE BACK OF THE FUEL FILTER THERES THE WATER DRAIN... TURN THAT AND BLEED SOME AIR OUT AND DO IT A FEW TIMES THAT SHOULD HELP THEN TRY STARTING IT UP AFTER A BIT
I took the new filter out to fill the bowl for good measure, and it was "vacuum sealed" ...air "popped" in when I broke the seal....is this what you mean by air?
It was "farting" a little, acting like it wanted to start, now it just whirls over with no hint of fire...I'm getting more and more pissed... |
Went back, opened the drain, fuel came out immidiately. Turned it over...nothing, not even a hiccup. Great.
KEEP TRYTING IT WILL FIRE UP
I have tried to the point that the batterys (NEW!! NEW STARTER TOO!) are dying down...I'll have to go pull them, and charge them next round.
When you turn the key can you here the fuel pump running?
I turn the key, and a loud hum comes from under the dash/hood/firewall, same as always since I bought it a year ago. After about 15 seconds it shuts off with a click, same as always.
The truck was getting "louder" as it ran low on fuel, like the last time I ran it out...Instead of just shutting it down, I ran it till it stalled, trying to find a place to pull over. I added fuel, it hiccuped like one cyl was firing...then nothing...I added even more fuel, and a new filter, it hiccuped, and then nothing. I replaced the filter in Nov, and it took a long time to get it running then, but it farted and made encouraging sounds at least. Now, zip, nada. |
Also, last time I ran it out, I added fuel and it started instantly...I know, don't run it out...I was headed to the station when it gave up this time..and last time I was ordered to go to my brothers immidiately for a family illness...no time for fuel that time..
