trouble code P0000 & P1000 ????????????? - Ford Powerstroke Diesel Forum
Old 02-17-2009, 02:12 PM
i checked my codes with my live-wire and got these 3 P0603,P0000,P1000 I found P0603 in the book but not the others any one know why? Also how bad is the P0603? thanks for any help
Old 03-09-2009, 06:02 AM
I have the same codes on my 2004 and like you wondered what they were. no clue yet- but I will spend more time with google today.
how is your truck running? mine idles rough and runs like it is missing- I also get a p0261 (and think after reading post here) that it may be a wireing issue- I will be checking tonight.
Old 03-09-2009, 08:33 AM
no idea on the P0000, but P1000 = OBDII monitors/drive cycle incomplete
have you recently disconnected the battery or cleared the pcm?
Old 03-09-2009, 02:47 PM
my truck was running bad witch is why i scanned it. Those were the only codes that came up i did kill the batteries a few days earlier probably why that code came up. i recently cleaned EGR valve runs great now!
Old 03-10-2009, 07:15 AM
yes- I cleared the codes on mine- the p0000 was there already but the 1000 came up after.
I droped the truck at a dealer today as I also had a p0261 injector code- and they are going to dig in. I have read about the 261 and figured I would have ford do the fix while I have an extended warenty in place- the 261 makes the truck really run rough.
