2004 6.0 No start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-13-2009, 09:01 AM Thread Starter
2004 6.0 No start
2004 F-350 with 6.0 powerstroke
wont start
Engine turns over, low plugs engage, fuel pump runs, but no dash lights turn on and will not start.
2004 F-350
6.0 L
5 inch custom exhaust
K&N cold air kit
ARP studs and black onix gaskets
Egr delete
With more money in parts then payments
cnidy1230 is offline
post #2 of 6 Old 02-13-2009, 09:08 AM
ADMIN AND TECH
SCUFFY828's Avatar
very vague on the details , really need more info, how it shut off , driving, parked etc.
ITS STOCK
SCUFFY828 is offline
post #3 of 6 Old 02-17-2009, 09:53 AM
very interested in your post.
I have an 04 6.0L doing pretty much the same thing. I would be really interested to know how you get this solved. My truck has been down since the end of November. I have changed Batteries, tested everything I can, but have no idea. Looks like I am going to have to pay a bunch of money to have it towed to the only Ford dealer here in Germany that has any experience with these truck and engines. Trouble is, he supposedly fixed this problem in November.........Good luck with finding the answer.
My post on a my 04's troubles is on page three of this forum...
HAK152 is offline
post #4 of 6 Old 02-17-2009, 10:15 AM
WEWILLE's Avatar
Does it crank, meaning does the starter engange and turn the engine?
ASE Certified Master Automotive/light duty truck Technician
ASE light diesel specialist
Ford Certified Diesel Technician
Isuzu Certified Gas/Diesel Technician
2007 F-250 PSD FX4 crew cab shortbox king ranch
2005 F-250 PSD FX4 crew cab short Box burned up
2013 Fusion 1.6L Ecoboost
2011 Ford Edge
1999 Dodge 2500 Cummins
WEWILLE is offline
post #5 of 6 Old 02-17-2009, 10:17 AM
WEWILLE's Avatar
My bad i have to read better, you need more info as scuffy said. I have heard of a shorted injector causing goofy dash light problems. What kind of scanner do you have?
2011 Ford Edge
WEWILLE is offline
post #6 of 6 Old 03-03-2009, 04:22 PM Thread Starter
Sry about the delay. I got it started. I was messing with the connections on the back of the fuse box and it started. went through and check the connections had a bad one. fixed it and have no problems.
2004 F-350
6.0 L
K&N cold air kit
Egr delete
