keepin truck warm - Ford Powerstroke Diesel Forum
Old 02-09-2009, 07:54 AM
keepin truck warm
i have a 2002 excursion with a 7.3 powerstroke diesel. the problem im having is that the truck wont start if its kept outside in temps under 32 degrees if its kept in garage with heat starts fine. my engine light is on and have had looked at they told me it is showing that the computer modular that runs the fuel injectors and glow plugs needs to be replaced. ford says there is a part called (injector modular) as im concerned they dont no much more than me!!! HELP!!!!!!
Old 02-09-2009, 07:56 AM
Using a block heater would help
Old 02-09-2009, 07:57 AM
ADMIN AND TECH
the glow plug module very well could be bad, and on an excursion will turn the check engine light on, if code says its bad , may want to get it replaced , does sound like thats your problem by the symptom
Old 02-09-2009, 07:58 AM
but i want it to start all the time not baby it its a truck!!!
Old 02-09-2009, 08:00 AM
ADMIN AND TECH
Old 02-09-2009, 08:15 AM
Do you plug it in at night when you leave it outside? Also, you might want to tell us which part of the country you live in...
Old 02-09-2009, 08:18 AM
ADMIN AND TECH
get this excursion checked , and fixed correctly, the modules arent that expensive , no need to plug it in if module is all thats wrong
Old 02-09-2009, 09:23 AM
i live in southeastern MI and yes i plug in or keep in heated garage! but the injector module is very expensive $900.00 glow plug module is $90.00 and does anyone no where to get after market parts for this?
Old 02-09-2009, 09:25 AM
ADMIN AND TECH
i doubt it needs a injector driver module , someone is telling you wrong
Old 02-09-2009, 09:30 AM
ya ford said it was the injetor drive module and an independent repair shop told me the glow plug module! but the cumputer reading is telling me that its the glow plugs and injectors! truck runs great when it starts.
