HeadGasket blown? - Ford Powerstroke Diesel Forum
Old 02-03-2009, 03:47 PM
HeadGasket blown?
ok so today i checked my radiator over flow and it had a green oil gew in it so i drained my radiator and flushed it. NOTE i blew my oil cooler a month ago and replaced it. but i have oil dripping off the side of my motor pass side that is. but i have no coolant in my oil. and truck is running good it seems like. ugh i am stumped
update here is a pickure of my coolant and headgasket isnt blown valve cover is tho
Old 02-03-2009, 04:03 PM
Feedback Score: 4 reviews
maybe when you flushed it you didnt get every drop of oil out.
Old 02-03-2009, 04:30 PM
if it is a head gasket the oil will normally go to the coolant. The oil is under what 60 psi? and the coolant isn't under but 10-20 psi. And if it's running good I doubt its a gasket, they normally smoke to beat all hell when one lets loose.
Old 02-03-2009, 05:02 PM
yea its not smoking i just cant figure it out it is killin me!!
Old 02-03-2009, 05:05 PM
7.3 head gaskets are pretty tough........
Old 02-03-2009, 05:11 PM
i hope they are
Old 02-04-2009, 11:22 AM
I'm guessing you didn't get ALL of the oil out. Headgaskets are normally smokers, and yes they are very tough, usually good to about 40 PSI however running straight water with no anti freeze can kill a headgasket over time also.
Old 02-04-2009, 11:40 AM
Ole White
I agree you might just have not gotten it all out Cory
Old 02-04-2009, 06:42 PM
yea i am only running water for this week just so i can flush it daily and not kill my pocket book
Old 02-04-2009, 06:48 PM
I don't think you got all the oil out. Run simple green threw it. Over at Ford when a 6.0 blows the oil cooler and mixes with the coolant they flush the system at least 4 times.
