99 F250 ECM woes - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-19-2014, 03:28 PM Thread Starter
Powerstrokin''s Avatar
99 F250 ECM woes
I had a hypertech 40 hp chip in my computer. I pulled the computer, took out the chip, and then plugged it all back in and now it will not start. It turns over fine, but will not fire. SES light is on when you turn the key on and when you crank the engine. I removed it all, re-installed the chip, and still the same results. Any thoughts? Is there any way to actually test the computer? It acted like this when the CPS went a couple of years ago, so I put the Ford upgraded CPS in and no problem. Thanks for any help.
Rob
Early 1999 F250 X/C Lariat 4X4 Off Road
Hypertech 40 HP Chip
DIY Tymar intake
Exhaust Brake
Grill Insert- color matched to truck
Rhino Liner- color matched to truck[SIGPIC][/SIGPIC]
GlassTite topper- color matched to truck
4" suspension lift
35" BFG All Terrains on Weld Cyclone rims
Powerstrokin' is offline
post #2 of 7 Old 07-19-2014, 04:13 PM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
Do you have a WTS light when you first roll-on the key?
NoRalPh is offline
post #3 of 7 Old 07-19-2014, 05:27 PM Thread Starter
No the WTS does not light up. Is there any way to test the computer such as a scanner or something. Or is it "dead" and I go buy a new one??
DIY Tymar intake
Exhaust Brake
4" suspension lift
post #4 of 7 Old 07-19-2014, 08:31 PM
Quoted: 728 Post(s)
Check the PCM/fuel bowl heater fuse.
Corey@CNCFAB is online now
post #5 of 7 Old 07-19-2014, 08:32 PM
Quoted: 728 Post(s)
Did you happen to remember to remove the keys out of the ignition when you pulled the chip?
post #6 of 7 Old 07-20-2014, 04:51 AM Thread Starter
Right I will check the fuse. I think the key was in when I disconnected the harness outside. I pulled the key when I opened the door to pull the box itself out.
DIY Tymar intake
Exhaust Brake
4" suspension lift
post #7 of 7 Old 07-20-2014, 10:18 AM
Quoted: 728 Post(s)
Im gonna say you probably fried your PCM. But i really dont know for sure. Are you able to hook up a good scan tool to see if you get comm error?
