Big Problem with my 01 7.3 power stroke
i am at the end of my wits with this truck right now
last week my truck started acting up like it had gelled fuel so i heated it the garage and used diesal 911. nothing helped changed the fuel filter no change. then when it was running i noticed it was draining oil all over. took it in and had the o rings replaced and turbo rebuilt. then my number 3 injector tested bad changed that. Today picked it up say crap. It will start and run drive it, it works fine then the check engine light comes on and then it will loose all power and slow to like 25 or just die and not restart Any ideas??? Randy truck is an 01 f250 |
have you had to codes run? how cold is it getting where you are? any mods on the truck?
reply
am gonna run the codes tomorrow
i am in minnesota so it has been very cold -10 to -40 windchill no mods after it dies and i tow it home or have it hauled it will start up and do the same thing again |
Have you tried the CPS? Possibly fuel pump going out.
cps?
i replaced the cam shaft postion sensor when i got it it was running like hell then, changed it and all was good maybe 2 months ago
is there a crank shaft sensor ?? or is that the same thing?> i drain the bowl and replaced the filter fuel fills right back up ?? is there a second filter or water seperator on these? |
Just the cam sensor no crank. Do you know what color CPS you put in? They can be bad right out of the box. There are screens and stuff in the fuel tank, but if it seems to be filing up the bowl pretty quickly that should be fine. The weird stuff like running fine, then just losing power or dying, and then starting up after waiting a while sounds a lot like it could possibly be the CPS.
the water separator is directly behind the fuel filter bowl. you turn it vertically and it drains. but as fordcowboy says, it may be a bad cps out of box
cps
when the cps went out before is just ran rough and would dies and lack of power this will not respond to throttle and hold just stay at a certain rpm? would accelerate mor ethan 25 sometimes.,
i was a white or creme it has been fine for 2 months no problems |
Well a bad CPS can do all kinds of different things, it isn't always the same symptoms. I've never seen a white or creme one. The only other things I can think of would be something in the high pressure oil system messing up the oil delivery. Are there any other symptoms like smoke of any kind. I'm not a tech or anything so hopefully someone that knows some more will see this. But it kind of sounds like trying another CPS might be the cheapest thing to try, and if it turns out that wasn't it, then you have a spare.
7.3 L '01
SOUNDS LIKE HIGH PRESSURE OIL PUMP LOOSING PRESSURE COULD BE O RING BLOWN ON IT.
