2000 7.3 Died on the road and will not start - Ford Powerstroke Diesel Forum
Old 01-21-2009, 07:54 AM
Hey guys I have a 2000 F350 with a 7.3, automatic with 123,000 miles and it cranked up fine yesterday and ran about 1/2 a mile and died and will not start back. It turns over fine but never fires at all. I checked the oil and (I am ashamed to say it was a gallon low) so I added a gallon thinking it may had triggured some sensor but it did not help. Any Ideas? Thanks in advance
Old 01-21-2009, 07:56 AM
Ole White
sounds like the CPS to me (Crank Postioning Sensor) this is a common problem with these trucks and is a recall that can be fixed for free at the dealer
when you say it died did it just shut off like you turned the key off??
Old 01-21-2009, 08:17 AM
Are you getting a wait to start light?
Old 01-21-2009, 08:18 AM
ADMIN AND TECH
thats was my first thought
Old 01-21-2009, 08:22 AM
Great minds think alike, but yours has way more knowledge about these than mine.
Old 01-21-2009, 08:42 AM
It cranked and ran fine for about 1/2 mile and it acted like the engine started slowing down until it shut off and now when I try to start it I get the normal lights and bells and the wait to start light goes out like normal but it just turns over and never even tries to fire up, I have already taken it in for the recall a while back so the cps (should) be good. Anything else that might cause this?
Old 01-21-2009, 08:45 AM
ADMIN AND TECH
there is alot of things that can cause this , really need to get a scanner on it to see what codes are in it
Old 01-21-2009, 08:52 AM
Send a message via AIM to jetskier2313
I still say the CPS I've been through 2 of them since I had the recall done. I would try replacing that and see if it changes anything, they don't cost much anymore.
Old 01-21-2009, 09:06 AM
did you have your truck serviced for the recall on the crankshaft sensor cuase when it whent out on mine it was runnin and just died goin down the road but once it cooled off it would run till it got to runin temp then die agin
Old 01-21-2009, 09:57 AM
ADMIN AND TECH
throwing parts cheap or not is the worst idea in the world , but do what you gotta do, it could be the cps , but a quick scan would let you know for sure
