motor grenaded Y?
rosewood diesel stage 3 hybrids
stealth stage 1 hpop dp tuner chip matched for injectors and banks big head waste gate pulling 10-11,000 lbs 68 mph 6spd so 1950 rpms cruise control out of blue BAM! chucks a rod out the oil pan drivers side rear cylinder the hole was on pass. side near pan rail around starter area had been pulling good so far I had that load on for 120 miles before it happened oil pressure was good. oil level was at add mark when I stopped so no problems there. WTF!!!!!!!!!!!!!!!!!!!!!!! I'm really upset about this not to mention the 150 mile ride home with a wrecker. Why would this happen. I wasn't even going up a grade. power turned down as low as it goes which is about 120-130 over stock. |
What engine?
Turned down to 120-130, if you've run it hard on the higher settings, it could have weakened the rods and they just decided to leave. |
what year 7.3? forged rods or pmr's
99 powerstroke built dec 98
never towed turned up never got a chance to sled pull with injectors motor wasn't even working hard |
for what it will cost to fix the engine in there right now i can put a p-puped cummins in. i think i might do that. any one want to buy a hpop and injectors
i got a clutch and fly wheel too. |
http://www.powerstroke.org/forum/tru...m-cummins.html |
You weren't in 80e were you?
Why would 80e cause problems?
greenbus pm a price for injectors hpop and tuner
