Please help I'm stuck in Delaware truck poured black smoke made a knocking noise then - Ford Powerstroke Diesel Forum
post #1 of 15 Old 07-04-2014, 05:39 AM Thread Starter
Cool Please help I'm stuck in Delaware truck poured black smoke made a knocking noise then
2000 f250 7.3. So two weeks ago I noticed smoke pouring out the exhaust at idol not thinking to much about it since it was hot out maybe a stuck injector but I kept driving made it home ok. Now I take the rigg from nj to Delaware and on my way at idol again it was pouring black smoke like never before tons of it and it had a weird knock sound from motor. It would only pour smoke when this knock was present. We'll I pushed the truck and it finially vibrated and shut off lost all power and had to roll to stop. Went to try to start it up and it seams locked it won't turn over I'm lost any ideas please
Stevejr is offline
post #2 of 15 Old 07-04-2014, 06:02 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Hydrolocked due to a cracked injector nozzle or stuck injector.
dhanna6powerstroke is offline
post #3 of 15 Old 07-04-2014, 06:41 AM Thread Starter
What's my next step please
Stevejr is offline
post #4 of 15 Old 07-04-2014, 06:48 AM
Mod Newbie
Quoted: 20 Post(s)
Pull the valve covers and start pulling glow plugs to see which cylinder is full of fuel.
post #5 of 15 Old 07-04-2014, 06:49 AM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
Pull the glow plugs until you find the one filled with diesel. That will be the one with the faulty injector.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #6 of 15 Old 07-04-2014, 07:05 AM Thread Starter
Sounds good thanks a lot. Now I have to try to get it home
Stevejr is offline
post #7 of 15 Old 07-04-2014, 07:51 AM Thread Starter
Can I just replace the bad injector or do I have to replace all 8
Stevejr is offline
post #8 of 15 Old 07-04-2014, 07:51 AM
ZMANN's Avatar
Quoted: 1583 Post(s)
sounds like you pushed this to the point your luck may have run out . ?
a hydro-lock at speed can do some internal damage ( any rpm hydro lock as a matter of fact)
what did the oil level look like ?
We Miss you Ronnie
ZMANN is online now
post #9 of 15 Old 07-04-2014, 07:54 AM Thread Starter
Oil level was at the mark to add oil not to bad
Stevejr is offline
post #10 of 15 Old 07-04-2014, 07:58 AM Thread Starter
The vibration before it shut off is what scares me. The injectors came from beans. Stage two
Stevejr is offline
