HELP 01 7.3 wont start - Ford Powerstroke Diesel Forum
Old 01-19-2009, 02:16 PM
Here's the rundown, I replaced all injectors, replaced valve cover harness's, replaced LPOP, replaced IPR valve. I cannot get the truck started unless I give it a shot of ether, after I do that then it runs fine, if I kill it I cant get it refired.. Im desperate now, I have now ordered an IDM (I have code 1316).
What else do I need to do or order??????
Old 01-19-2009, 02:21 PM
duct tape & zip ties
Did you replace the fuel filter.
Old 01-19-2009, 02:32 PM
No I have not there seems to be plenty of fuel in the bowl.. plus there's less than 2000 miles on the filter..
Old 01-19-2009, 02:35 PM
Mileage on a filter doesn't mean much. You can get a dirty tank of fuel and clog that filter up quickly.
Old 01-19-2009, 02:36 PM
I will head to town and pick one up.. anything else??
Old 01-19-2009, 02:42 PM
Scan for codes, what temp has it been down there.
Old 01-19-2009, 03:30 PM
New filter didnt help, it was 65' here today. i have an IDM fault code and thats it. 1316,
I will install a new IDM tomorrow. Im at my wits end.
Old 01-19-2009, 03:36 PM
What do you think about the IPC, I pulled the plug but there was NO oil in there, anyway to ck the IPC to see if its functioning??
Did you have the IDM code prior to doing the other work.
Old 01-19-2009, 03:38 PM
yes it was present, This things been hard to start since I installed the injectors..
