help please - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 Old 07-03-2014, 12:03 PM Thread Starter
Unhappy help please
so this is my first time on the forum, but anyways i have a 2004 f250 6.0 pretty much stock other than strait pipe and a bullydog , so it all started as me pulling out into traffic and i heard a loud popping sound then i couldnt build boost so i thought its was just a intercooler hose that blew off , so i replaced all the boots and tubes ,still didnt fix it so i replaced turbo still didnt fix it ,so i replaced map senor and ebp sensor and still nothing and its not trowing any dtc's anybody have any idea what it could be ??????
joshwilliams is offline
post #2 of 11 Old 07-03-2014, 01:15 PM
Quoted: 7 Post(s)
Is there a hose/tube of some sort that goes to the MAP sensor on a 6.0? If there is, did you check to make sure it didn't burst?
Pikachu is offline
post #3 of 11 Old 07-03-2014, 01:38 PM Thread Starter
No it all seemed to be ok
post #4 of 11 Old 07-03-2014, 01:39 PM Thread Starter
Yeah ive already checked that
post #5 of 11 Old 07-03-2014, 07:23 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 349 Post(s)
Sounds like vgt solenoid took a crap. Its rare but it does happen.
I you rev it up in park. Does it start to break up and blow black smoke?
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #6 of 11 Old 07-03-2014, 08:23 PM
6.0Stroker's Avatar
Quoted: 935 Post(s)
you should be able to unplug the VGT solenoid with it running.. it goes from a higher pithed whistle to a deep drone tone, then its working....
if it makes no difference plugged in or unplugged, then you've located your problem..
MIKE "HOSS" THOMAS
'03 F350 6.0 6-speed
~EGR Delete~Ported Intake Manifold~4in Diamond Eye Dual Exhuast~Blue Spring~50MM Turbosmart BOV~PMM Coolant Filter~
~155/stock Warren Injectors~Terminator Engineering T500 HPOP~SouthBend Dual Disc Clutch~RCD Stg 2 Camshaft~
~'03 Nighthawk turbo w/Wicked Wheel2
~Rebuilt and Studded by Toren~
6.0Stroker is offline
post #7 of 11 Old 07-03-2014, 08:58 PM Thread Starter
Its a brand new turbo and vgt
post #8 of 11 Old 07-03-2014, 09:15 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
I'd start by removing the Bully Dog and see what it does stock. FWIW, I wouldn't reinstall it either.
john galt likes this.
dhanna6powerstroke is offline
post #9 of 11 Old 07-03-2014, 09:17 PM
6.0Stroker's Avatar
Quoted: 935 Post(s)
I went threw 2 brand new IPR valves that were "brand new" 3rd one finally worked.. and in the mean time I spent almost $1500 on an HPOP thinking that was my problem.
turned out I had a bad IPR from Ford...
I have been selling parts for anything from lawn mowers to race cars to boats to heavy equipment..
It is rare, but just because it is new, doesn't mean that's not your problem.
Parts are assembled and/or rebuilt whether by machine or person, and not everything is good to go out of the box.. I have done my fair share of defective warranties on "new out of the box parts".. just sayin..
MIKE "HOSS" THOMAS
post #10 of 11 Old 07-06-2014, 10:11 PM
john galt's Avatar
Quoted: 1179 Post(s)
I lost an alternator in sacramento and went through 6 ...yes 6 of them before I found one that worked! and IT only worked for about a year before it started having problems!
so as stated new isnt always better ..just sayin
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, sinister coolant filter(this is the ONLY pos sinister product that will ever be on my truck), riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
Tags
6.0 boost , no boost
