Can't connect PCIM - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-03-2014, 07:16 AM Thread Starter
nt99sd's Avatar
Send a message via Yahoo to nt99sd
Can't connect PCIM
When i connect pcim motor runs rough the stalls . I don't have a scanner , and also truck is mostly a stock 7.3 with 180000 miles. I changed the exhaust tube and sensor already. with the sensor disconnected the truck runs perfectly. I know its not the sensor it's been changed two times. How do i fix this issue, this is my only ride.
nt99sd is offline
post #2 of 4 Old 07-03-2014, 07:23 AM
ZMANN's Avatar
Quoted: 1597 Post(s)
Bump
what is a pcim sensor?
We Miss you Ronnie
ZMANN is offline
post #3 of 4 Old 07-03-2014, 07:34 AM
sbluke55's Avatar
Quoted: 553 Post(s)
Garage
I believe you have your terminology wrong. Attachment 307650
Is any one of these the plug your talking about.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 4 Old 07-03-2014, 12:17 PM
Quoted: 7 Post(s)
Are you talking about the ICP sensor on the front top of the left head, by chance?
Pikachu is offline
