HELP no start 911! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-30-2014, 03:58 PM Thread Starter
Lightbulb HELP no start 911!
2001 7.3 f250
Got back from Home Depot and the truck wont start
no Crank from starter or anything just one click
i jumpstarted the starter and still nothing
and yes the batteries have charge
what can cause this??
any ideas?
stroke77450 is offline
post #2 of 8 Old 06-30-2014, 04:26 PM
My buddies just did that. Little wire to starter burned off at the end of it. I had him put key on, in run position. I ot under it from wheel well area and jumped it.(screwdriver) then had to replace the wire end.
2008 6.4 f250 lariat 4wd
melmount is offline
post #3 of 8 Old 06-30-2014, 04:28 PM
I reread yours, you jump started the starter, it wont crank it? If cables are good, batteries good, then dead starter. If you are trying to jump the starter it makes narrowing it down easy. Takes key switch, relays etc out of the issue.
melmount is offline
post #4 of 8 Old 06-30-2014, 04:44 PM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
HELP no start 911!
Crawl under the truck and give the starter a few good wacks. You could also jump the solenoid with a screw driver. Put your screw driver on the big post on the starter and touch the small post.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #5 of 8 Old 06-30-2014, 04:52 PM Thread Starter
when i jump started it
the starter spun like it wanted to start.
but didnt sound like normal
does that mean its just weak
and i need a new one?
post #6 of 8 Old 06-30-2014, 05:38 PM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
So you jumped the truck? Or you jumped the starter?
01 f-250, Standard
sbluke55 is offline
post #7 of 8 Old 06-30-2014, 05:40 PM Thread Starter
the starter
post #8 of 8 Old 06-30-2014, 06:44 PM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
Try jumping the starter relay on the passenger fender. If it works. Replace it. It's cheap. It should look something like this. It's off of a 97 but it's just like yours. Attachment 306786
01 f-250, Standard
sbluke55 is offline
Tags
7.3 , no start
