Just died - Ford Powerstroke Diesel Forum
Old 01-18-2009, 05:02 AM
Just died
I was pulling my camper, probably went 25 miles, all the while the truck seemed to not have much power, i could not shift into 6th (couldnt keep speed up) came to an intersection and it DIED, would not recrank, now while cranking i have no oil pressure on the idiot gauge.. PLEASE HELP I have to drive it to work tomorrow..
Old 01-18-2009, 05:38 AM
Illiana Chapter Director
Does the tach. jump while cranking?
Old 01-18-2009, 05:52 AM
Tach doesnt move either..
Old 01-18-2009, 05:55 AM
Your CPS (Camshaft Position Sensor) probably crapped out. There was an open recall on them. You could check with Ford and have them run your VIN# to see if your truck is affected.
Old 01-18-2009, 05:58 AM
I did have that changed at the dealer about 6 months ago.
Sounds to me like it's bad again. If they didn't get the gap right, that can cause it to fail prematurely.
Old 01-18-2009, 06:01 AM
ok so i will try to get another one, autozone and orielly are the only things open today, are they good for those parts??
Old 01-18-2009, 06:02 AM
Don't even know if they carry them. Ford should take care of it for you since they did it 6 months ago. Only thing is, you are without your truck.
Old 01-18-2009, 06:04 AM
Thanks I will keep this thread up to date as I change things, nice day to work on the truck, its supposed to be near 70' today
Old 01-18-2009, 06:05 AM
Wish it was like that here. It's snowing here now.
