help 99 7.3 stalling while driving - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-16-2009, 03:13 PM Thread Starter
BRS
Ok, been driving at least 45 mins in 10 deg weather about 50mph constant, push on accelerator and no response then truck starts dying. SES light comes on, make it to top of exit ramp and it finally dies. Let it sit for a min and starts back up but really rough. Then let it idle for 15 mins in a parking lot, again really rough. Then it died again. Any ideas folks?
99 F350 7.3L, auto.
Thanks,
Ben
Ben
Early '99 7.3L F-350 SRW SC LB
DP Tuner (NS,Stock,HI 1200, DT,40T,80T,80E,120R,140A), Coolant Filter, External Trans Filter, 6.0L Cooler, JW Stage I Trans, Dipricol Optix Gauges, AFE Stage II, MBRP 4" Turbo Back, ProComp 4" Lift Front, Skyjacker 6" Rear Leafs w/ 1" Block, 16x8 MT Classic II's
BRS is offline
post #2 of 12 Old 01-16-2009, 03:17 PM
(1) Check screen in pressure regulator bolted to side of fuel filter. Clean with carb cleaner.
(2) Fuel pump is getting old.
(3) Fuel pickup screen in fuel tank is blocked.
(4) fuel filter is clogged.
Diesel Monkey is offline
post #3 of 12 Old 01-16-2009, 03:18 PM
CompressionIgnitionAddict
99ildually's Avatar
Gelled up ? Try a new filter.
-Josh
Early 99 F-350 2wd DRW
6 Speed 4.10 rear
4 in turbo back muff delete
Intake Superchip & 4k mod
99ildually is offline
post #4 of 12 Old 01-16-2009, 03:51 PM Thread Starter
BRS
Thanks guys, I've got a spare filter, so I'll try that first. Thought my fuel treatment would stave off the gelling in these frigid temps, but maybe the filter is just too dirty.
Ben
BRS is offline
post #5 of 12 Old 01-16-2009, 03:58 PM
GoldieStroker944's Avatar
it almost even sounds like an idm problem but could be a fuel delivery problem too
2003 7.3L
Crew Cab Short box
Lariat
Cowl (functional)hood
315/75-16 wild coutry A/T's
Hypertech power programmer 3
T.S 6pos
stock,high idle,50,75,100,140
AFE stage 1
Foil delete
MBRP Cool Duals 6" tips
Sirius sat radio
GoldieStroker944 is offline
post #6 of 12 Old 01-16-2009, 04:05 PM
CPS......?
gonestrokn is offline
post #7 of 12 Old 01-16-2009, 04:11 PM
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
Originally Posted by gonestrokn View Post
CPS......?
X2
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #8 of 12 Old 01-16-2009, 05:34 PM Thread Starter
BRS
Just got it towed and there's a giant oil puddle all underneath it, and underside is covered in oil, so that explains the lack of fuel. There's oil between the trans and block underneath, not much oil in the valley, so must be the back side of the turbo.
Ben
BRS is offline
post #9 of 12 Old 01-17-2009, 02:51 PM Thread Starter
BRS
Filled with oil today, started in the driveway, and let it run for about 10~15 minutes. Ran for about 10+ minutes before oil started dripping, then a slow stream started. Looking in the valley with a flashlight, I saw a steady stream dead center in the valley flowing from the front underneath the HPOP. At least 3 quarts poured out while I was watching.
Pulled the HPOP, but now I'm lost. From the label, this is obviously a rebuilt pump. I bought the truck in April, with little history on it. It doesn't look like the hose connections leaked. Do people ever get leaks on the plate where the HPOP bolts to the block? I've seen several posts on this (see arrow) bolt leaking, but I can't tell if that's what it was or not. Any ideas folks?
ID:	7498   Click image for larger version
Ben
BRS is offline
post #10 of 12 Old 01-17-2009, 03:10 PM
Mine leaked out of that bolt. I pulled the bolt out and the O-ring was half gone and deteriorated. I bought an O-ring kit from ford for that O-ring and the O-rings for the fittings where the 2 lines go into the pump and that fixed it. At first i thought mine was leaking out of the gasket where the pump meets the block so i put a new gasket on and it still leaked and then i found the O-ring problem. Hope this helps.
00forddiesel is offline
