6.0 Powerstroke, 2003. Crank but no start. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-27-2014, 10:00 AM Thread Starter
bwk
I know, another 6.0 crank but no start. I have read through the other posts on the forum and have googled my way to confusion. I have a scanner and recorded some data.
A few notes:
- I have fuel.
- Fresh batteries
- Fuel pressure at high pressure rail is good. I just replaced the return pressure regulator spring with the "blue" one.
- Plenty of oil.
- Fuel filter fills up when I crank.
- Seems like the low pressure oil is good - hard to tell.
- Fuses are all good.
My scan data during a crank. Engine sounds like it is trying hard:
Trying to start - cranking
RPM: 147 RPM
EGR Valve Position - Volts: 0.78 Volts
ECT Failure Mode: 0
EGR Duty Cycle: 0%
EGR Status / Failure Mode: 0
EGR Monitor Completed: 0
EGR Open Circuit Detected: 0
EGR Valve Position Actual %: 0%
EGR Valve Position Desired %: 0%
Battery Positive: 10.94 - 11.50 Volts
FICM Information for Sync: 1
FICM Logic Power: 11.0 Volts
FICM Main Power: 40.0 Volts
FICM Vehicle Power: 11.0 Volts
Injector Control Pressure Actual (PSI): 1798 PSI
Injector Control Pressure - Desired (PSI): 1764 PSI
Injector Control Pressure - Volts: 2.22 Volts
Injector Control Pressure Regulator %: 50%
Injector Timing Deg BTDC [-512 - 512]: 6.28
Pressure Control Failure Mode: 0
Water in Fuel: 0
I live up in the woods and towing this thing to the dealer + repairs will be really expensive. The wife is getting a little tired of being a one-car family though so I need to get it running.
Any ideas???
Thank you.
bwk is offline
post #2 of 4 Old 06-27-2014, 07:28 PM
When you say engine is trying hard what do you mean? Like almost starting or the starter dragging?
DieselBreathDude is offline
post #3 of 4 Old 06-27-2014, 07:51 PM
DesertSmoker's Avatar
2 thing that don't seem right
that seems real high for no start motor should fire at 700 psi
that might indicate a bad FICM = no start
For Sale--2003 F-250 CC 4x4 SB 6.0
Custom 03 Turbo, WPE Intake,
HD 97 Fan Clutch, MBRP Y Pipe,
Scangauge II Rancho 9000XL,
BFG 285/75 R16, Galaxy 94HP
DesertSmoker is offline
post #4 of 4 Old 11-27-2014, 02:05 AM
GunnyRappUSMC's Avatar
FICM needs MINIMUM 48V to fire off... Id start there... Check Batteries for a dead cell... (Alot cheaper to buy batteries than a new FICM)
Rapponotti, M.T.
Gunnery Sergeant
USMC 1st MARDIV
2005 6.0L F-250 LARIAT CCSB, 4X4, Auto 281K miles
CREW CAB, EGR Delete, 4" Turbo Back, Straight Piped (Bully Dog Triple Dog... Just for Gauges
Project Truck
2003 F350 Lariat, CCLB, 4x4, Auto, 6637 Mod, Gunny HUD Mod, 98,627 ORIG MILES
PARKED PENDING INSTALL OF THE
7.3 SUPER BLACK MAMBA MOTOR
GunnyRappUSMC is offline
Tags
6.0 starting , no start
