Fuel leak, 99 7.3, 85k miles. Not the drain valve!! - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-26-2014, 07:13 PM Thread Starter
My first post guys but Im in a pickle. I'm leaving on a 6 hour drive towing my Jeep to Kentucky in two days and my beloved 99 SD 7.3 decided to be cranky :-(
I'm leaking a good bit of fuel while running only at the front/center of the engine on the passenger side. Its not the drain valve, the valley is dry. There is very little fuel at the end of the drain tube and its not coming from there. I just changed the filter three days ago, it started leaking today.
I need this fixed fast and cheap(yeah I know)
TIA!
Jon
Edit; This is a early 99 with a production date of 4/99
xjtrailrider is offline
post #2 of 11 Old 06-26-2014, 08:03 PM
sbluke55's Avatar
Quoted: 590 Post(s)
Garage
Check your filter cap and see if it's coming from there. Best I can say is start it up and start following lines. But the filter cap is easiest to get to.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 11 Old 06-26-2014, 08:22 PM
Fuel lines going to the filter base?
2008 6.4 f250 lariat 4wd
melmount is offline
post #4 of 11 Old 06-26-2014, 08:52 PM Thread Starter
There is no fuel in the valley of the engine. The cap, drain valve or the lines are NOT leaking, the HPOP is not leaking. Its coming from somewhere in the front or front middle of the right bank(pass side) I hear there is a fuel rail plug there somewhere behind the AC compressor bracket that the orings go bad on. How big of a deal is it to fix that?
post #5 of 11 Old 06-27-2014, 01:22 AM
Can you post a pic?
DieselBreathDude is offline
post #6 of 11 Old 06-27-2014, 03:21 AM
Quoted: 7 Post(s)
The fuel rail plug on top of the head is pipe thread and has no o-ring. There are end plugs on the fuel rail that use a banjo bolt with an o-ring. I believe you have to remove the accessory bracket to get to it if you find out that it's your leaker.
Pikachu is offline
post #7 of 11 Old 06-27-2014, 03:39 AM Thread Starter
Originally Posted by DieselBreathDude View Post
Can you post a pic?
I will try, I'm heading out to the garage right now to tear into it
Its at the front of the engine and near the motor mount. There is fuel all over the battery cable and all of the suspension/crossmember etc is soaked.
post #8 of 11 Old 06-27-2014, 04:11 AM
Quoted: 7 Post(s)
If it's leaking from the end plug and running down, it's probably being blown back onto the motor mount and everything else. I've never actually ran across one that was leaking, but I'm sure it can happen. The oil rail end plugs leak occasionally, and it's pretty much the same design.
Pikachu is offline
post #9 of 11 Old 06-27-2014, 04:23 AM Thread Starter
This is 100% fuel! too clear and thin to be Rotella 15-40! I'm digging in now. I had to move my trail rig out of the way to pull it in
post #10 of 11 Old 06-27-2014, 05:06 AM
Quoted: 7 Post(s)
I know you said it's fuel. I was just pointing out that the oil rail end plugs are the same design as the fuel rail end plugs.
Pikachu is offline
