250 miles from home - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-22-2014, 05:24 AM Thread Starter
250 miles from home
I'm about 250 miles from home and I think my egr cooler is messing up I pulled the valve and had a half inch of build up on the bottom and it was starting to get pretty moist not soaked yet I have only lost like 1/4 inch of coolant out of my degas bottle should I be able to limp it home to put in the shop
6litercumminseater is offline
post #2 of 3 Old 06-23-2014, 12:13 AM
you either take the chance or have it towed or have a friend come help.let's back up here a sec.
is your truck puffing white smoke now or showing any signs out the tail pipe that would make you think your egr cooler is going bad or did you just decide to pull egr valve and make your own conclusion.
fatbastardf350 is offline
post #3 of 3 Old 06-24-2014, 06:39 PM Thread Starter
I was driving and the little rubber house that goes from my intake to the sensor by my turbo came off and I lost all boost my check engine light came on and I limped it to AutoZone and got a clamp to put on it boost is back but it seems it's still not running right
