05 6.0 raw diesel smoke - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-21-2014, 02:37 PM Thread Starter
Ok so I was mudding a couple weeks ago and sucked water in through my intake and through the turbo my truck bogged down and eventually died. After about an hr we finally got it started and it blew white smoke like crazy until at operating temp now a couple thousand miles later and all new 8 injectors it still blows white smoke and misfires at start up IT'S NOT COOLANT EGR OR HEAD GASKETS HAVNT ADDED A DROP SINCE I BOUGHT THE TRUCK 3 YEARS AGO anyways it's raw diesel and only until operating temp then it's fine I did notice more turbo lag and a loss of power it also bucks while coasting/ braking up to red lights less than 5 mph I have put new glow plugs and new injectors it's not throwing any codes I am starting to really wonder what I have done to it maybe a valve or possible glazed cylinder but if that's the case I would think it would be missing all the time not just at start up
6litercumminseater is offline
post #2 of 4 Old 06-22-2014, 09:08 PM
you have what is called STICTION ISSUES.
how long do the injector or in injectors miss.
fatbastardf350 is offline
post #3 of 4 Old 06-22-2014, 11:49 PM Thread Starter
Generally until right at operating temp
post #4 of 4 Old 06-23-2014, 12:57 AM
well you can pull the injectors and remove the spool valve and use a very light abrasive
to polish and put back in.but you could also get some rev x or other lubricant and see if it cures your problem.
