Turbo Bad? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-14-2014, 07:06 AM Thread Starter
Turbo Bad?
I was told my turbo likely needed to be cleaned, was blowing more black smoke than usual when i footed it. I started to pull it apart this morning and this is what I found. Note the chip in the blade! Also, how much shaft play should there be, I can move the shaft around quite a bit...probably 1/16" total play (1/32" up and down).
Do I even bother cleaning it? Can I just get a new wheel? rebuild it? replace the whole turbo (208K miles)?
2003 F250 6.0L - Bulletproofed, AFE CAI
Powderxp is offline
post #2 of 7 Old 06-14-2014, 09:23 AM
Wrenchslinger's Avatar
To my knowledge you should have no shaft play ( saying this because I've installed three new turbo's this past week and none had any shaft play i could detect while pre oiling them).
Wrenchslinger is offline
The Following User Says Thank You to Wrenchslinger For This Useful Post:
Powderxp (06-14-2014)
post #3 of 7 Old 06-25-2014, 12:31 AM
I had my turbo (6.0L - Garret) apart two weekends ago and there was no noticeable shaft play. I've seen replacement parts online but if yours already has 208K miles, I would spent the 1K and get a new one or maybe an upgraded one.
You could always run it a bit longer until it really is noticeable boost wise. It depends on how much you enjoy taking the turbo in and out of the truck.
Seattle60 is offline
post #4 of 7 Old 06-25-2014, 04:06 AM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Slight lateral play is ok but zero axel play. I would tear it apart could be just a compressor wheel. What kind of cold air intake do you have, something must have gotten sucked in. Might want to invest in a better filter. There is an awesome sticky on how to rebuild the turbo.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #5 of 7 Old 06-25-2014, 04:12 AM Thread Starter
Thanks, not sure what you mean by lateral and axial? Could you clarify?
Powderxp is offline
post #6 of 7 Old 06-25-2014, 04:14 AM
Lateral play is side to side and axial is in and out.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #7 of 7 Old 06-25-2014, 04:19 AM
You know since you got it all apart if you wanted to upgrade you can contact WPE for a 1.5 kit. This would be a nice upgrade and priced reasonable.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
