Truck Died on way home?!? - Ford Powerstroke Diesel Forum
post #1 of 33 Old 06-11-2014, 09:38 PM Thread Starter
scoutcamper's Avatar
Quoted: 55 Post(s)
Garage
2002 F250 7.3L with 202K Miles.
Driving home from work, doing 55 mph, all of a sudden the truck starts to slow down, gas pedal does nothing, rpm drops to zero, truck is DEAD. Thought maybe out of fuel(sort of felt like it ran out, but not quite, hard to describe). Called a friend, got 2 gallons of diesel, added to tank(Fuel gauge shows 1/4 tank at this point) Press the water/fuel dump lever and get some fluid out the bottom, which tells me fuel is in the bowl, didn't suck air. Crank the truck and it will run for about 2 seconds, and then dies, when it runs it is really rough(shake truck really hard and bad rough), and after trying over and over until the trucks batteries are dead, i have it towed home. Got it home, charged up, now it just cranks and cranks, sounds like its about to start(fires a time or 2 on its own) and then just keeps cranking. Checked with OBD 2 reader, no codes, but cranked it to the point that the computer lost power, so if there were codes they are gone now...
Suggestions? Ideas? Help??
Thanks,
Scoutcamper
NEW:2016 F250 6.7L Crew Cab Short Bed XLT Fx4
MODS: Ham Radio Install. LED Cube Reverse Lights.
2002 F250 Crew Cab 7.3L short bed. GONE @ 222,000Miles
scoutcamper is offline
post #2 of 33 Old 06-11-2014, 09:45 PM Thread Starter
Quoted: 55 Post(s)
Garage
Also have a hypertech hyperpac tune installed. I can remove it and flash back to stock, just wondering the reprocussions of doing this while the truck wont run. any thoughts?
post #3 of 33 Old 06-12-2014, 07:23 AM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
First, the computer doesn't lose a hard code from a power loss But, you'll Always need more than an OBD-II scanner to retrieve a code from our trucks (which are Not, specifically, OBD-II). Get the right scanner on it and find-out what is going on.
Next, put 5 more gallons in the tank. Two is an insignificant amount in a big tank and there's a common delivery problem that starts at 1/4 tank (couldn't hurt to try). Then, insure the pump runs by putting your hand on it and feeling it and run it for 15secs. Drain the bowl and collect what comes out in a cup. Do this a second time and compare what you get to confirm fuel delivery.
Also, as your crank the batteries low you have to keep-up with recharging them because once the voltage drops too low the computer won't trigger the IDM to fire the injectors (an '02 isn't as sensitive to this as earlier trucks but it's a waste of time if you allow it to get too low)
If you can get it to run for more than a couple of seconds, maybe hold the pedal down some, you should also check that you have the same amount of "heat" in each exhaust manifold (just 30 secs and you can run-around and feel them over the ft tires) to know you haven't lost a side to a bad UVCH or IDM.
Anyway that's where I'd start
NoRalPh is offline
post #4 of 33 Old 06-12-2014, 07:31 AM Thread Starter
Quoted: 55 Post(s)
Garage
I am wondering if perhaps this could be a cam position sensor failing. Thinking back(after a good night of sleep) sitting at the stoplight before i got up to speed(turn left at stoplight, about 1/8'th of a mile later is when it croaked) it had a miss(it was idling louder and rougher, didnt click at the time that that was happening). So add a miss to my symptoms and i believe that leads us to the CPS? I still have the OEM black one, never had the recall done. Should i have it towed to the dealer and get the recall done?(after flashing computer back to stock of course)
When i take my lunch break i will dump 5 gallons of diesel in it, but i tested that when someone is cranking it i can press the yellow dump lever on the back of the fuel bowl and fuel shoots out the bottom with force, which i think means i am getting fuel?
I have the truck on battery chargers now and have a friend with an 02 7.3 who is coming over tonight to be a power feed and help me diagnose this(he has the propper computer reader, i have a $12 odb2 reader for my miata that happens to plug into the truck and read some codes sometimes)
Thanks,
Scoutcamper
post #5 of 33 Old 06-12-2014, 08:20 AM
Quoted: 143 Post(s)
It could be a CPS I guess but, your description isn't typical of one (when they first start failing, they usually "fix" themselves once they cool-off) In either case a scan would let you know. Do you have anything that would show you cranking rpm? That would confirm it's function (the tach used to be a good indicator but no longer in an '02).
I saw you dumped the fuel bowl but, to confirm fuel delivery you have to do it more than once and is why I suggested it. Sounds like you have done that now.
See if you can get it to run a bit longer...
NoRalPh is offline
post #6 of 33 Old 06-12-2014, 08:29 AM Thread Starter
Quoted: 55 Post(s)
Garage
Yeah, i did dump the fuel bowl more than once, and got about an equal amount each time. There is no rpm showing either on the dash or on my obd2 ebay reader, which is why i am thinking CPS. It right now will not run at all. The only time i got it to cough and sputter was on the side of the road and im not sure why it wont do that now(towed it home, now it wont do anything but crank).
post #7 of 33 Old 06-12-2014, 09:14 AM
Vannnce's Avatar
Quoted: 13 Post(s)
A CPS from ford is only like $23.00. Its always good to have one in the glove box. If i were you, id go to ford and buy one. put it in. If it fixes it, great, if not, you have a spare in case it ever poops out on the road.
You might look into the torque app. that will allow you to dig a little deeper and monitor icp and ipr values. NoRalph, do you know if that app(obd port) gets its rpm reading from the same place as the tach? I guess i could run out and check on my 02
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #8 of 33 Old 06-12-2014, 11:59 AM Thread Starter
Quoted: 55 Post(s)
Garage
Well, CPS changed, things have now improved(i think?)
Truck has gone from just cranking, nothing ever firing, to now it cranks, then you can hear 2-3 cylinders start to fire, and keep cranking, its like its starving for fuel now. I am guessing by dumping the fuel bowl i added air into the system and with some continuous cranking the air will get out of the system?
Thoughts?
post #9 of 33 Old 06-12-2014, 12:28 PM
Vannnce's Avatar
Quoted: 13 Post(s)
Did you cycle the key several times to let the bowl fill back up? When i drain my bowl, ill cycle the key about 4 times for thirty or so seconds each to let everything fill back up
-Vance-
I.B.E.W. Local 1002
Vannnce is offline
post #10 of 33 Old 06-12-2014, 12:31 PM Thread Starter
Quoted: 55 Post(s)
Garage
Nope, didnt even think about that. Back at work now but will be home in about 4hrs, hopefully that fixes it
