HELP!!! Charging system wire diagram
My 04 is not charging there is no field current going to the alt no voltage drops on ground or hot so what I need is a diagram or someone who can tell me what the green\red and orange\blue wires do and where they go to to hopefully fix this problem Thank in advance
I have a haynes manual but it only show a 02 diagram with different wiring colors than mine
Try this. If you need others let me know.....
Thats what I'm looking for perfect Thanks
So it turns out that the the field wire was pushed back in the connector but the real problem was my voltage regulator I happened to have a old alt with one in it to get her going but it takes about 2min for the voltage to come up to 14 so i will pick one up tomorrow and see if thats the cure but thanks for the help. For the record the light green/red is the switched power to the indicator light\field coil and the orange\light blue is constant power |
