help egr cooler removal now no power - Ford Powerstroke Diesel Forum
Old 01-04-2009, 09:43 AM
I put a liberator egr cooler removal kit in and I lost power like a exhaust brake is on but I dont have one. 2005 f250, this is my first 6.0 and I have only had it 7 days. At this rate I will go back to the 7.3s I have owned and worked on for 10 years. I took everything back apart and put it back together but still the same problem. no ces light or anything.
Old 01-04-2009, 09:57 AM
Do you have a drive pressure leak, or boost leak???
Old 01-04-2009, 11:53 AM
It sounds like exhaust is blocked, a pressure leak before turbo. Is there a plate or something in the turbo that has the exhaust blocked to the turbo?
Old 01-05-2009, 08:25 PM
Did you make sure the y-pipe to turbo flange were mated up properly and clamp seated? I agree with Dusty sounds like a drive pressure leak somewhere.
