glow plug issue
ok I need some input on the glow plug system. I have power out of the GPR, 13 volts on both posts . How can I test from there on to see where the problem is.
I have 2 new batteries new altenator, glow plugs and harnesses are new from last feb. The truck will not start if it is not plugged in and sit for a few hours. This is causing problems, any where I go I have to plug it in if I'm going to be there a while. This is not a state to have a starting issue in, I can not leave town with this truck right now with the fear it wont start if I cant plug it in, and there are no plugs in the mountains lol.
What ever it is it just went out. A month ago we had a cold front come through and it got pretty cold. The first night it blew in the truck started at -7 below, no problem. But the the next day would not start and it sat for 2 weeks before we could get it started, even plugged in, granted it was -28 below. Then it warmed up and we finaly got it started. Now it will only start if it is plugged in even if it is 40 degrees out. I have never had a start issue with this truck before this.
Thanks for the help
