ICP SENSOR PIGTAIL REPLACEMENT ISSUE!!!!!!! - Ford Powerstroke Diesel Forum
post #1 of 1 Old 05-23-2014, 05:26 PM Thread Starter
PROBLEM! CHANGING OUT THE ICP SENSOR PIGTAIL! I TOOK ONE WIRE AT A TIME OFF AND MATCHED THEM UP WITH THE OLD/NEW PLUG AND EVERTHING WAS FINE UNTIL I CHECKED TO MAKE SURE THE CRIMP ON THE BUTT SPLICE WAS HOLDING AND TWO OF THEM CAME OFF! NOW I DONT KNOW WHICH ONES TO MATCH UP! IS THERE A PLACE WHERE I CAN LOCATE THE ORIGINAL FORD COLOR CODES SO I CAN MAKE SURE I HAVE THE RIGHT CONNECTIONS!
rhranch is offline
